Ansys Learning Forum Forums Discuss Simulation 3D Design Problem curl 35 error activate discovery Re: Problem curl 35 error activate discovery
Subashni Ravichandran
Hello NOVACAD
Can you please check if the customer has any Firewall enabled?
Also, can you please check if they have a proxy server setup?
If so, can you please go through #5A & #5B of the Discovery License Activation Troubleshooting
If these solutions do not work, please share the files as mentioned in the #6 of the above page.
