3D Design
3D Design
Shape Jumping (Spaceclaim R3 2023)
    • Christof Schramm
      Please take a look and the attached PDF. When I form a rectangle in the sketch mode, I often use direct inputs of dimensions. Since the upgrade on R3 the rectangle jumped to a wrong position when I hit the "Enter" key after putting in the last dimension.
      Is this a software problem?
      Best Regards,
      Christof Schramm
    • subashni.satish
      Hello Christof Schramm
      I've not see this issue before.
      It may have something to do with the model you are working on.
      Can you please share the model so that I can check at my end?
    • Christof Schramm
      pleas find attached the model.
    • Christof Schramm
      I have installed the patch, but the problem still exists further on. Sorry.
      Best regards,
      Christof Schramm
    • subashni.satish
      I'm able to replicate this behavior. This seems to be specific to this file. I will be filing a bug for this.
      In the meantime, as a workaround, can you create the geometry and then use to move tool to drag it into its correct position?
    • subashni.satish
      817382 BUG ID
    • Christof Schramm
      Hello Subashni,
      I will try it tomorrow, OK?
      Best regards,
      Christof
    • Christof Schramm
      I have noticed, that spaceclaim behaves sometime a little weared after importing some files (STEP, IGES, OBJ). The most problems I have watched where with the 2D-sketch tool for example in placing parallel lines to some curves and when I worked with eliptic elements.
Viewing 7 reply threads
  • The topic ‘Shape Jumping (Spaceclaim R3 2023)’ is closed to new replies.
