3D Design
3D Design
Graphics Issue with Discovery Install
    • lisa.lust
      Here is the output of the test
      C:UsersE731679>"C:Program FilesANSYS Incv231FrameworkbinWin64Ans.DriverSetup.exe" --check-system-compatibility
      OPENGL_VERSION  = 4.6.0 NVIDIA 452.66
      OPENGL_VENDOR   = NVIDIA Corporation
      OPENGL_RENDERER = Quadro P3000/PCIe/SSE2
      OPENGL_EXTENSIONS = WGL_ARB_buffer_region WGL_ARB_create_context WGL_ARB_create_context_no_error WGL_ARB_create_context_profile WGL_ARB_create_context_robustness WGL_ARB_context_flush_control WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_multisample WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_pixel_format_float WGL_ARB_render_texture WGL_ATI_pixel_format_float WGL_EXT_colorspace WGL_EXT_create_context_es_profile WGL_EXT_create_context_es2_profile WGL_EXT_extensions_string WGL_EXT_framebuffer_sRGB WGL_EXT_pixel_format_packed_float WGL_EXT_swap_control WGL_EXT_swap_control_tear WGL_NVX_DX_interop WGL_NV_DX_interop WGL_NV_DX_interop2 WGL_NV_copy_image WGL_NV_delay_before_swap WGL_NV_float_buffer WGL_NV_gpu_affinity WGL_NV_multisample_coverage WGL_NV_multigpu_context WGL_NV_render_depth_texture WGL_NV_render_texture_rectangle WGL_NV_swap_group
              found: WGL_NV_DX_interop2
              found: wglDXOpenDeviceNV
      Found OpenCL Platforms:
              Name[Intel(R) OpenCL HD Graphics]
              Profile[1]
              Vendor[Intel(R) Corporation]
              Version[3.0.0 [ ]]
              Extensions[
                      cl_khr_byte_addressable_store
                      , cl_khr_fp16
                      , cl_khr_global_int32_base_atomics
                      , cl_khr_global_int32_extended_atomics
                      , cl_khr_icd
                      , cl_khr_local_int32_base_atomics
                      , cl_khr_local_int32_extended_atomics
                      , cl_intel_subgroups
                      , cl_intel_required_subgroup_size
                      , cl_intel_subgroups_short
                      , cl_khr_spir
                      , cl_intel_accelerator
                      , cl_intel_driver_diagnostics
                      , cl_khr_priority_hints
                      , cl_khr_throttle_hints
                      , cl_khr_create_command_queue
                      , cl_intel_subgroups_char
                      , cl_intel_subgroups_long
                      , cl_khr_il_program
                      , cl_intel_mem_force_host_memory
                      , cl_khr_subgroup_extended_types
                      , cl_khr_subgroup_non_uniform_vote
                      , cl_khr_subgroup_ballot
                      , cl_khr_subgroup_non_uniform_arithmetic
                      , cl_khr_subgroup_shuffle
                      , cl_khr_subgroup_shuffle_relative
                      , cl_khr_subgroup_clustered_reduce
                      , cl_khr_fp64
                      , cl_khr_subgroups
                      , cl_intel_spirv_device_side_avc_motion_estimation
                      , cl_intel_spirv_media_block_io
                      , cl_intel_spirv_subgroups
                      , cl_khr_spirv_no_integer_wrap_decoration
                      , cl_intel_unified_shared_memory_preview
                      , cl_khr_mipmap_image
                      , cl_khr_mipmap_image_writes
                      , cl_intel_planar_yuv
                      , cl_intel_packed_yuv
                      , cl_intel_motion_estimation
                      , cl_intel_device_side_avc_motion_estimation
                      , cl_intel_advanced_motion_estimation
                      , cl_khr_int64_base_atomics
                      , cl_khr_int64_extended_atomics
                      , cl_khr_image2d_from_buffer
                      , cl_khr_depth_images
                      , cl_khr_3d_image_writes
                      , cl_intel_media_block_io
                      , cl_khr_gl_sharing
                      , cl_khr_gl_depth_images
                      , cl_khr_gl_event
                      , cl_khr_gl_msaa_sharing
                      , cl_intel_dx9_media_sharing
                      , cl_khr_dx9_media_sharing
                      , cl_khr_d3d10_sharing
                      , cl_khr_d3d11_sharing
                      , cl_intel_d3d11_nv12_media_sharing
                      , cl_intel_unified_sharing
                      , cl_intel_simultaneous_sharing
              Name[NVIDIA CUDA]
              Profile[1]
              Vendor[NVIDIA Corporation]
              Version[1.2.0 [ CUDA 11.0.228]]
              Extensions[
                      , cl_khr_fp64
                      , cl_khr_byte_addressable_store
                      , cl_khr_icd
                      , cl_khr_gl_sharing
                      , cl_nv_compiler_options
                      , cl_nv_device_attribute_query
                      , cl_nv_pragma_unroll
                      , cl_nv_d3d10_sharing
                      , cl_nv_d3d11_sharing
                      , cl_nv_copy_opts
                      , cl_khr_gl_event
                      , cl_nv_create_buffer
                      , cl_kernel_attribute_nv
      [2      ][dbgerr][19828] AssertFailedException: "NVAPI_OK == p_status" - void __cdecl `anonymous-namespace'::CheckStatus::Check(const enum _NvAPI_Status,int)
      At:
              [0]00007FF62DD2F1FE              (0)
              [1]00007FF62DD30301              (0)
              [2]00007FF62DD29062              (0)
              [3]00007FF62DD2CCF8              (0)
              [4]00007FF62DD25E1F              (0)
              [5]00007FF62DD1183C              (0)
              [6]00007FF62DD13728              (0)
              [7]00007FF62DD430F0              (0)
              [8]00007FFA99FB7614     BaseThreadInitThunk      (0)
              [9]00007FFA9ADC26A1     RtlUserThreadStart       (0)
      Failed to add/update profile.
      NVidia driver installation found.
      Driver: 45266
      Branch: r450_00
      Found an existing profile: Ansys Workbench Products
      settings:
      Enable application for Optimus(0x10f9dc81) = 1
      Shim Rendering Mode Options per application for Optimus(0x10f9dc84) = 0
      Optimus flags for enabled applications(0x10f9dc80) = 1
      applications:
      Found an existing profile: Ansys ACP
      settings:
      (0x20335bca) = 0
      Error occurred during profile update.
      exception: AssertFailedException: "NVAPI_OK == p_status" - void __cdecl `anonymous-namespace'::CheckStatus::Check(const enum _NvAPI_Status,int)
      ********************** ERRORS *********************
      [1      ][dbgerr][19828] NVAPI call failed with: NVAPI_INVALID_USER_PRIVILEGE @269
      [3      ][dbgerr][19828] NVAPI: Failed to check profile.
    • Devendra Badgujar
  • The topic ‘Graphics Issue with Discovery Install’ is closed to new replies.
