Ansys Products
Ansys Products
Workbench/Fluent DPI scaling issues on 4k screen
    • JollyRoger
      I have just installed ANSYS on my laptop which has a 4K screen. When I opened Workbench after installing, everything was extremely small, so I put an override on the high DPI scaling through the compatibility tab. This made everything bigger and readable, albeit a bit blurry. However when I go into a meshing screen, or any windows that have a model viewer section (such as Fluent), everything is all over the place.
      I have changed the application properties for Fluent and Workbench now several times and tried all different combinations of DPI scaling, however I am starting to think this is more a problem with ANSYS than anything, as all my other programs work fine with the 4K screen. The laptop was ISV certified to work with ANSYS, so I don't know how this got through.
      My question is, how do others use ANSYS on 4K screens?
    • tsiriaks
      Hi JollyRoger ,
      Have you tried changing the "Scaling performed by" option to "System(Enhanced)" instead of application , as indicated by AnirudhMS  from this post
      /forum/forums/topic/installation-issues/
      Once, that is done, open up Windows File Explorer and go to
      %AppData%    (please copy and paste this in the Windows Explorer address bar)
      then rename the folder ANSYS to anything else, such as ANSYS.old
      Does this make any differences ?
      Thank you,
      Win
  • The topic ‘Workbench/Fluent DPI scaling issues on 4k screen’ is closed to new replies.
