August 1, 2018 at 2:42 pm
sameep11
SubscriberI am going through the edx hand on course but stuck there in 1.5 homework i gone through all the lecture but dont able to get the output below is my work plz someone help me in removing it
August 1, 2018 at 5:07 pm
Sandeep Medikonda
Ansys EmployeeHi sameep,Â
Please provide more details on what is wrong and what your expectations are from the results?
~Sandeep
August 1, 2018 at 6:26 pm
August 1, 2018 at 7:30 pm
August 2, 2018 at 3:51 am
sameep11
Subscriberwhat is Bcs? -
August 2, 2018 at 4:04 am
sameep11
Subscribergot it i have put the same bcs -
sameep11
Subscriberbut ig not 2d conduction
thanks for the reply -
August 2, 2018 at 11:17 am
peteroznewman
SubscriberIf you are referring to where my image says: A: 1D with Internal Heat Generation, that is because I renamed the system block from Steady State Thermal on the Project page of Workbench. That can be useful when you have several blocks on the page since the label shows up in the plots!
I don't see any images in your reply. You have to save to a file before you can add them to your post. You can grab and paste from the clipboard. Is your model giving the correct temperature now?
August 2, 2018 at 11:59 am
August 2, 2018 at 5:03 pm
August 2, 2018 at 5:19 pm
August 2, 2018 at 8:12 pm
peteroznewman
Subscribersameep11,
In your post above, no one here is going to give you the correct answer to a question from the edX course.
In your post two above, I see you have a material called sameep that has the thermal conductivity property, but the drop down menu is covering up the value assigned and the units.
I ask again, is your model now giving the correct temperature result?
August 3, 2018 at 1:43 am
sameep11
Subscriberno my temp is wrong -
August 3, 2018 at 11:56 am
peteroznewman
SubscriberYou didn't show a screen snapshot of your model with the boundary conditions, the way I showed in my screen snapshot.
August 28, 2018 at 7:00 pm
sameep11
SubscriberMay i have your mail id?
August 28, 2018 at 7:01 pm
sameep11
SubscriberI have got the same result as yours but dont get the right temp value yet
August 28, 2018 at 7:49 pm
DrAmine
Ansys EmployeePlease be more precise about your questions? Are you now asking about Fluent or still regarding ANSYS with the edx workshop? If yes show the screenshot of your model with all boundary conditions as highlighted by peteroznewman
- The topic ‘issue with the solver’ is closed to new replies.
5934
1306
.jpg?width=690&upscale=false)
