Ansys Learning Forum Forums Discuss Simulation General Mechanical Changing Body Dimension in API Reply To: Changing Body Dimension in API
ErKo
HI
The easiest is just to go to the system and change under the Geometry/Properties, the Analysis Type to 2D.
As for your question related to mechanical scripting:
You need another line to set dimensions to 2D:
        Body.Dimension=ShellBodyDimension.Two_D
        Body.Behavior=Model2DBehavior.PlaneStrain
All the best
Erik
