August 5, 2023 at 11:43 am
August 6, 2023 at 1:16 am
Dev
Ansys EmployeeHello,
You can use this example : Silicon solar cell with TiO2 pyramid array – Ansys Optics
For inverted pyramid please see the post response: Creating an Inverted Pyramid structure (ansys.com)
Thanks
August 6, 2023 at 2:21 am
Kawshik
SubscriberThank you. I have designed structure using the aforementioned tutorials but the structure which I designed isn’t actually look like the above one which i got from a paper. I need how to make a inverted pyramid hole shape. Or how to make the base of the pyramid hole like structure to easily penetrate another pyramid into it.
August 6, 2023 at 2:12 am
Kawshik
August 6, 2023 at 3:15 am
Dev
Ansys EmployeeHello, As I mentioned in previous response please look into this post: Creating an Inverted Pyramid structure (ansys.com) you can make hollow geometry. Its explained step by step there. I am also copying the response here.
“Hi, you can either rotate the existing group 180 degree around y axis and shift it to the proper position. this example uses old technique of layered rectangles; or you can build up your own periodic inverted Pyramid by your own using the pyramid in object library:
what you need is to flip the sizes of the tip and the bottom:
it can be a solid pyramid, or can be air by use of 'etch' material mesh order.”If you like to have one pyramid on top of another repeat the same step again by adding another array of pyramid.
For understanding mesh order : Understanding mesh order for overlapping objects – Ansys Optics
Please try it.
- The topic ‘How to design a period of hollow inverted pyramid?’ is closed to new replies.
6520
1311
