August 5, 2023 at 10:04 am
Abasiodiong Jackson
SubscriberHi,
I am unable to extract the mass and stiffness matrices of my model on ANSYS 2022 R2 with the basic apdl commands
*SMAT,MatKS,D,IMPORT,FULL,file.full,STIFF*PRINT,MatKS,Ksparse.txtÂeven though I have done this in the past on a different ANSYS version and I have seen someone achieve this with the 2022 R2 version. I see the following lines in the solution outputÂEXPAND ALL EXTRACTED MODES
 DO NOT CALCULATE ELEMENT RESULTS
 DO NOT COMBINE ELEMENT SAVE DATA FILES (.esav) AFTER DISTRIBUTED PARALLEL SOLUTION
 DO NOT COMBINE ELEMENT MATRIX FILES (.emat) AFTER DISTRIBUTED PARALLEL SOLUTION
 DO NOT COMBINE ASSEMBLED MATRIX FILES (.full) AFTER DISTRIBUTED PARALLEL SOLUTIONÂ
I wonder if it has anything to do with my my settings and configuration. I would really appreciate some help.
August 7, 2023 at 12:21 pm
Ashish Khemka
Forum ModeratorHi,
Can you please check the DMPOPTION command? The DMPOPTION command controls how solution files are written during a distributed memory parallel (Distributed ANSYS) solution. This command is most useful for controlling how results files (.RST,.RTH, etc.) are written.
Ashish Kumar
- The topic ‘Unable to export mass and stiffness matrices on ANSYS 2022 R2’ is closed to new replies.
5824
1305
