August 2, 2023 at 9:32 am
Milad
SubscriberI have a Mixing Case. Liquid Liquid Dispersion, Water(continuous phase), Gasoline(dispersed phase)
Note: Both Phases at the inlets are continuous and after going through the mixer Gasoline becomes dispersed in the water.
I want to capture This Process ( Breakage) and Predict the Max Diameter of Drops in the flow.
I am currently using the Eulerian method to capture the multiphase nature of the flow and k~e for Turbulence.
Questions
1. How to Capture the Breakage from continuous to disperse for Gasoline?
2. How to Find the Maximum Drop Diameter and Distribution of Drops? -
August 2, 2023 at 11:02 am
Forum ModeratorWith the Eulerian multiphase model you'll see the second phase disperse (or rise/sink) depending on the set up. For break up or agglomeration you'll need population balance.Â
August 2, 2023 at 2:01 pm
Forum ModeratorThe Eulerian second phase has a diameter which is either fixed or can vary if using population balance or some other phase change mechanism: each diameter is a different phase if you don't use population balance. What did you set for the phase properties?
- The topic ‘Static Mixer Dispersion’ is closed to new replies.
