June 19, 2018 at 12:22 pm
chris1992
SubscriberHello!
I want to simulate a simple body which is producing its own heat. The produced heat depends on the temperature of the body and should be considered as different functions (3 functions) or as a table (produced heat over temperature). I have no experience with ANSYS and I also read many manuals but I didn't find anything useful for me. Could somebody please help me? Thanks in advance.
Best regards.
Christopher
June 19, 2018 at 9:02 pm
peteroznewman
SubscriberHello Christopher,
I'm interested in helping. Please make a sketch of the shape of the body and post an image in your reply. You also have to define the thermal conductivity of the material.
For each surface of the body, you have to say what happens to heat at that surface. The choices are: insulated, fixed temperature, convective heat transfer, or fixed heat flow (leaving out Radiation from this list for simplicity).
Best regards,
Peter
June 20, 2018 at 4:32 am
chris1992
SubscriberHello Peter,
thanks for your quick answer.
The shape of the body is a simple rectangle with very thin thickness and looks like this:
Size of the elements are all the same. Thermal conductivity in plane is 20W/mK, perpendicular to it its nearly 1 W/mK.
Actually I'm working with an other program and I only want to know if the implementation of a Heat Generation is possible in the way I thought.
Therefore every element of this body should produce its own Heat. The Heat Generation should be described by different functions or by a table
depending on the elements temperature.
Best regards,
Christopher
June 20, 2018 at 10:42 am
peteroznewman
Here is a simple model and you can see that Function is one of the choices for Internal Heat Generation,
while Tabular is only as a function of time.
And while TEMP is the variable name of nodal output temperatures for results, it apparently doesn't like it in this formula.
I'm going to need some help here from experts in the community. Let's see what others can contribute.
Peter
Attached is an ANSYS 18.2 archive.
June 20, 2018 at 8:00 pm
chris1992
thank you very much. That's exactly the information I was searching for. Maybe there has to bei added some information at the "TEMP"-part for the function. In LS-DYNA there has to be written TEMP(293) for example for the Node oder Node-Set with the ID 293.
Have you heard of this thermal mass and how the heat generation in dependence of the temperature can be included in the simulation?
Best regards,
Christopher
June 20, 2018 at 10:02 pm
peteroznewman
Subscriber -
June 21, 2018 at 11:46 am
peteroznewman
Attached is a model that puts one MASS71 element on each face of a thin body.
I could instead put a MASS71 element on each node, but that would be 16 edits instead of 9 and I was short on time : )Â Â
I haven't yet figured out how to write the code that puts the A1 - A6 coefficients onto those elements, so maybe someone in the community can help.
Best regards,
Peter
ANSYS 18.2 archive is attached.
June 23, 2018 at 11:01 am
chris1992
I'm very thankful for your support. I will discuss your input with my colleagues next time. Simultaneously I'm trying to do this simulation with LS-DYNA and I think this is working quite well.
Best regards,
Christopher
July 12, 2019 at 10:07 am
tianshixiang1993
SubscriberHello Chris,
Have you sovles the problem? I meet the same challenge as you in the setting of Ansys. Could you please share the solution if you overcome it?
May 23, 2020 at 11:56 am
Kainze
SubscriberHi,
any advice how you use TEMP as a variable for the internal heat generation?
Best regards
Kain
May 24, 2020 at 4:02 pm
- The topic ‘Heat Generation’ is closed to new replies.
