June 15, 2018 at 5:15 pm
learn13
SubscriberIn the attached picture is the pressure results along the length of a 2D channel with a bump on the bottom wall. Â
I'd like to obtain similar plots but from a 3D model. I'm thinking I'll have to define a place and get the results I'm after that's akin to the 2D data.
I'd appreciate any help!
June 15, 2018 at 6:51 pm
raul.raghav
SubscriberYou can create a line in CFD-Post and plot the Pressure vs Length graph. Refer the following youtube video for reference:
June 15, 2018 at 7:00 pm
vganore
Ansys EmployeeDefine a plane under your 3D model, and plot the pressure contours.Â
Good option Rahul regarding plot but looks like lean 13 need a line with a bump in the middle to plot the data on that line. In that case, only creating a line may not help.Â
I assume your 3d model would be symmetric and you would be able to select and name your required edge under ANSYS meshing to pull the line with a name under Fluent for selection. Once done, proceed for plot under Fluent. Â
- The topic ‘CFD Pressure XY Plot’ is closed to new replies.
5824
1305
