July 26, 2023 at 10:04 am
Sandra Pérez Barrio
SubscriberI would like to know how to add a compressibility to a material. This one in particular (grey one) compresses 45% at 5000psi out of plane. With this compressibility, it would fill the gap that appears in the image. I have tried to play with the young's modulus and the poisson's ratio to get it, but to get that 45% deformation I would have to put a ridiculous young's modulus, in the order of 80 Pa. This material has different in-plane and out-of-plane properties (graphite). With the young's modulus specified in the catalog, the compressibility is almost zero (1e-10 m). Could someone tell me how to define this property in engineering data? Thank you very much.
.png)
July 26, 2023 at 7:07 pm
peteroznewman
SubscriberHello Sandra,
Use a Gasket material and mesh the compressible layer with SOLSHELL190 elements. You need the solid body of the gasket to be meshable with a Mesh Method of Sweep. You need to mesh a single layer of elements through the thickness, then you can use a Gasket material on that body.
/forum/forums/topic/element-solsh190/
The Gasket material allows you to define a table of pressure vs closure.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/ans_mat/gask.html?q=gasket
- The topic ‘How to add compressibility?’ is closed to new replies.
4708
1565
1386
1242
