Ansys Learning Forum Forums Discuss Simulation General Mechanical steady state thermal: radiation + heat flux Reply To: steady state thermal: radiation + heat flux
eugenio benedetti
Hi Sampat
I tried several simulation with different boundary condition. First I used the same model but with higher dimensions to have more radiation.
I also obtained temperature of 10^6 K, depending on the value of the heat flux. With Higher heat flux the simulation gives not coerent results.
I think that a boundary condition of heat flux on a high surface as in my model (high surface relative on the dimensions of the problem) is "too rigid". So this gives numerical problem on the simulation.
