Ansys Learning Forum Forums Discuss Simulation General Mechanical GAP between midsurface and 3D part Reply To: GAP between midsurface and 3D part
mertturgut.senol
Ok yes I solved this problem by viewing error message like you showed.
I adjusted midsurface offset type to the top, it should be middle.
when I changed offset type to the middle it is ok.
