Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Non equilibrium porous media simulation fluent › Reply To: Non equilibrium porous media simulation fluent
July 19, 2023 at 8:03 am
Non-equilibrium porous media should do what you need - check the documentation and if in doubt build a 2d test model. I assume the casing around the porous zone is well insulated?Â
