Ansys Learning Forum Forums Discuss Simulation General Mechanical Not enough constraints appear to be applied. Simple shaft Reply To: Not enough constraints appear to be applied. Simple shaft
ErKo
Hi
I think it is ok and it should run – you aborted it that is why it's red (arrows).
Finally you can also run with weak springs on.
See here how to do that:
https://featips.com/2020/05/14/weak-springs-yes-or-no/
All the best
Erik
