May 22, 2018 at 9:57 pm
omareg94
SubscriberI'm getting persistent error in mesh check.
I've generated the mesh mentioned in this previous question. Also it gets errors.
I'm following this tutorial (but with the structure mentioned in the previous question).
I've generated a new simpler mesh (attached) and getting the same problem also.
I'm not able to figure out why check mesh always gives errors.
May 23, 2018 at 12:24 am
May 23, 2018 at 3:05 am
May 23, 2018 at 4:12 am
omareg94
SubscriberI think updating Mesh wasn't the problem as I have been making sure I updated Mesh then refreshed setup all along the way and it was giving me the same mesh check error (with my Setup options there). Yes it gives no check error before setting up the options of the Setup phase (with Setup options reset). After setting up the options of the "Setup" phase, and trying to check, it gives check errors.
I want to attach these two files: aaa2-f_test1.wbpz: My file making sure that Setup options I want to apply have been set. meshFix2D_test1.wbpz: Your file updated with the desired Setup options have been set.
Both files give check errors after setting these options up.
When I click Initialize, I get:Â
WARNING: Limited wall distance for 1 cells to 1.000000e-12.
And when I click calculate, I get:
Divergence detected in AMG solver: x-momentum
Which is most probably because mesh errors.
May 23, 2018 at 11:45 am
omareg94
SubscriberI forgot to mention that I'm using version 18.0
May 23, 2018 at 2:19 pm
- The topic ‘Mesh check is failed’ is closed to new replies.
4673
1565
1386
1236
