Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Lumapi – Insufficient Memory even though I have memory › Reply To: Lumapi – Insufficient Memory even though I have memory
July 13, 2023 at 7:35 pm
Did you find the solution as this post was closed?
Usually I suggest to test the Lumerical script first to make sure everything works fine when Python script causes some issues.
Currently creating geometris with Python is a little slow which is under improvement. Please use struct for parameter assignments to improve the efficiency.
