July 13, 2023 at 9:02 am
July 13, 2023 at 1:28 pm
Federico
Ansys EmployeeHello,
RPC is a Remote Procedure Call. Which version of Fluent are you using? Do you get the following messages in the Console before those that you are showing?
To avoid getting these messages, please try the following:
Open the Ansys installation folder.
~/.ansys/v231/ApipUserConfig.txtÂ
(Here, replace 231 with an appropriate value)
Verify that the following lines are included:
ANSYSProductImprovementProgram=off-
July 13, 2023 at 1:46 pm
July 14, 2023 at 1:00 pm
Federico
Ansys EmployeeYou can find the printout from the Console in the session's transcript file (.trn). You can find this file in the session's working directory. Please see if there are any messages prior to this RPC call.
July 14, 2023 at 5:23 pm
Victor
SubscriberThanks. No other message. "RPC RCX_MESSAGE: RPC: Timed out" appeared 23 times. This message never comes alone, either 2 or 3 times in a row.Â
Which file should I change?Â
July 17, 2023 at 2:39 pm
Federico
Ansys EmployeeActually, if you do not see that Ansys Product Improvement Program message, the RPC call might not be related to this. So need to look for the files suggested previously.
May I ask how are you running this simulation? Are you running it locally on your machine or submitting a job on a hpc cluster?
July 18, 2023 at 7:10 am
Victor
SubscriberIt is run on a local machine.
- The topic ‘what does RPC mean?’ is closed to new replies.
