Ansys Learning Forum Forums Discuss Simulation General Mechanical Cohesive (Adhesive) behavior ANSYS mechanical Reply To: Cohesive (Adhesive) behavior ANSYS mechanical
Amiri Savage
Hi Erik,
Thank you so much for responding. Another question I had was how do you determine the material properties of the CZM material. I wasnt sure where i could find maximum normal traction, or normal separation across the interface. Is this something that we should assume? Also I assume this would change if I wasnt creating a model with a premade crack, correct?
Thank you,
Amiri Savage
