July 12, 2023 at 4:35 pm
dobiej
SubscriberHi All
I've run into a problem where when I create an FDTD instance in Lumerical I get an error mid-way through build saying
"The program must be terminated due to insufficient memory."
I have 128GB RAM and 4TB storage so this isn't an issue. I've tried increasing the mesh size but to no avail.
What's strange is if I build it manually I can run it fine. Would anyone know what the issue could be? I've tracked it on Task Manager and there doesn't seem to be a spike in specs or anything.
Any help would be appreciated.Â
July 12, 2023 at 8:05 pm
dobiej
SubscriberFor reference here is the first first part of the code. Specifically I get the error on line 59. Above there are just variables that define things.Â
The x span is set to be 1 micron with conformal variable 0 mesh and the background index is set to 1.333.Â
When I set the x span to be 10nm the program is not shut down due to insufficient memory but the elements are added to the build extremely slowly (140 seconds to add 5 elements). Before it used to start running the simulation in under 10 seconds. Nothing has changed but this has happened all of a sudden.Â
When I construct this in GUI it works fine and I can use python to load files and save them just not create new ones.Â
July 13, 2023 at 7:35 pm
Guilin Sun
Ansys EmployeeDid you find the solution as this post was closed?
Usually I suggest to test the Lumerical script first to make sure everything works fine when Python script causes some issues.
Currently creating geometris with Python is a little slow which is under improvement. Please use struct for parameter assignments to improve the efficiency.
- The topic ‘Lumapi – Insufficient Memory even though I have memory’ is closed to new replies.
