Ansys Learning Forum Forums Discuss Simulation Fluids How to work with DPM UDF in steady state? Reply To: How to work with DPM UDF in steady state?
If you're using fluid sink/source terms how are you defining the "time" taken for material being added to the cell? The source is something/m3/s so if the particle time step is small you not be adding enough on the fluid side.
