Ansys Learning Forum Forums Discuss Simulation Preprocessing Unable to import geometry into fluent mesher Reply To: Unable to import geometry into fluent mesher
Essence
Is your geometry clean? Make sure it does not have any clearances or gaps. If there are faults in the geometry, I would suggest you to use Fault-tolerant meshing.
