Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Missing Fluid Flow (Fluent) from Ansys 2023 Workbench toolbox › Reply To: Missing Fluid Flow (Fluent) from Ansys 2023 Workbench toolbox
July 11, 2023 at 11:55 am
Hi Dana,
Can you please try the below options:
- Can you close all Ansys applications, then go to “C:\Users\user_name\AppData\Roaming” or type %appdata% in the address bar and rename the “Ansys” folder to “Ansys. old”?
- Once done, relaunch the application and check if the required extensions are visible.
- Can you try to “reset workbench” from the view option?
Let me know if this works for you.
