Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Problem with controle pore fluid, pore pressures in soils › Reply To: Problem with controle pore fluid, pore pressures in soils
July 10, 2023 at 11:51 pm
Konstantine,Â
I will give the following general tip that typically, pore-pressure problems use LOAD_BODY and INITIAL_STRESS_DEPTH to include the effect of gravity.Â
You can search for the following paper online "Modelling liquefaction of soils with LS-DYNA using a SANISAND-based material model", as it has some discussion of modeling pore-water-pressure problems.
Also, please be sure to read through the Remarks under CONTROL_PORE_FLUID and INITIAL_STRESS_DEPTH in the latest versions of the manual
