July 8, 2023 at 10:13 am
bara . H
SubscriberHello,
I am currently trying to simulate a bending test on a round bar of nitrided stainless steel.
So my question is, how can I set the material parameters for the layer offset from the surface with a gradient of Young's modulus and Poisson's ratio?
Typically, nitrided layer will have a maximum Young's modulus and minimum Poisson's ratio at the surface and gradually become the same parameters as the substrate as it approaches the substrate. Also, the layer will uniformly cover the model like a coating.
I would like to know the solution to reproduce such a layer with a gradient in the material parameters.
Hopefully some experts can provide guidance on resolving this issue and helping me out!
Thank you very much!
Best regards,
July 10, 2023 at 12:40 pm
Ashish Khemka
Forum ModeratorHi,
Please see if the following link helps: Hold my Beer: Spatially Varying Materials in Ansys Mechanical Made Easy - PADT (padtinc.com)
Ashish Khemka
July 20, 2023 at 1:34 am
bara . H
SubscriberHello Ashish,
Thank you very much for your help.
I'll do my best to accomplish my task.
Kind regards
Bara
- The topic ‘Reproduction of nitrided layer with gradient in material parameters’ is closed to new replies.
5824
1305
