Ansys Learning Forum › Forums › Discuss Simulation › STEM › Effect of Surface Area in Convection in Steady State Thermal Simulation › Reply To: Effect of Surface Area in Convection in Steady State Thermal Simulation
July 7, 2023 at 12:06 am
When I said average h, I was considering using a constant for h, but sure, there are other options for a variable h rather than just importing a time or spacial varying value from a linked fluid system or "External Data." You can use an equation in x,y,z, or time, or use tabular with Temperature as independent variable, or import time or temperature dependent data.
