Ansys Learning Forum Forums Discuss Simulation Fluids OSCILLATING PLATE FSI WITH FLUENT AND MECHANICAL Reply To: OSCILLATING PLATE FSI WITH FLUENT AND MECHANICAL
Jayakumar Jayaraman
Thank you for the information. I have tried the above tutorial for the oscillating plate with CFX and Mechanical as explained in the tutorial. It explains the making animation of Mesh displacements, Incremental Displacement, Force per unit area, etc., It would be very helpful if you could guide how to check and display the Total deformation, and Von Mises stress of the solid body (plate) on the Esight interface. Also, Is it possible to do the coupling analysis of the aircraft wing in the fluid domain following the same setup? Thanks
