    • Marius Carrier
      I'm using fluent with out the workbench. Now that I'm finished with my simulations I have trouble opening my case and data in CFD-Post, I tried lodaing it into workbench but that doesn't work because the data is so big that the solution times out before it finishes and so I can't open post there. How do I import my data and case into cfd-post without workbench?
      thanks for the anwser
    • SRP
      I suggest you to check fluent user's guide: 3.14. Exporting Solution Data after a Calculation (ansys.com)
      This helps you to understand how to export the files.
      Thank you.
  • The topic ‘CFD-POST’ is closed to new replies.
