Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Tensile Testing via Explicit Dynamics › Reply To: Tensile Testing via Explicit Dynamics
July 5, 2023 at 12:43 pm
Ram Gopisetti
Hi,Â
you have deficint material model, Â UTS, 0.2% yield strength, elastic modulus, and Poisson's ratio are not sufficitent , you also need to model the plasticity definition, your material model should look like as follows (ideal, example)
you need to use an failure critieria from the engineerign data as followsÂ
then you need to make sure that the failure is used by mateial not of geomentric strain limitÂ
cheers, RamÂ
