Ansys Learning Forum Forums Discuss Simulation Preprocessing SpaceClaim how to split a fluid domain into 2 Reply To: SpaceClaim how to split a fluid domain into 2
peteroznewman
The volume extracted solid in SpaceClaim has no special feature, it is the same as all other solids.
When you use the Share button in SpaceClaim, it shows in green highlighting which face pairs will be replaced with a shared face.
When you open the geometry in Mesh, you can identify the body as a Fluid.
