Ansys Learning Forum › Forums › Installation and Licensing › Ansys Free Student Software › FLUENT, Drag on 2D cone analysis › Reply To: FLUENT, Drag on 2D cone analysis
June 26, 2023 at 3:43 pm
Coefficients are always an odd one: the forces are just read from the pressure/shear results. As it's a coefficient the area you need is based on whatever you're comparing with: ie how did you compute the coefficient from the experiment. However, they are convenient and often used inside Fluent for the particle drag laws.
More usefully, Google of "drag coefficient formula cones" (lose the quotes) has a decent article from Aerospaceweb.org which seems fairly comphrensive.
