June 17, 2023 at 7:43 amZaid Abd Al-Hadi SubscriberHey
 is it applicable in MAPDL to define two individual materials (fiber and matrix) then APDL itself can produce the resulting lamina
 and use it as the material definition in the section command? if yes, how to do this?Â
 best regards,
June 20, 2023 at 2:54 pmAshish Khemka Forum ModeratorHi, I am not sure if this example might be of help to you:   How to access the ANSYS Online Help  Regards, Ashish Khemka -
June 21, 2023 at 3:38 amZaid Abd Al-Hadi SubscriberThanks!
June 20, 2023 at 3:12 pmGovindan Nagappan Ansys Employee  You can use Material Designer tool in Workbench and compute the Lamina properties from Fiber and Matrix properties you have. Then you can pass the properties to Mechanical or use it in Mechanical APDL. For doc check here: Ansys Product Help    -
June 21, 2023 at 3:44 amZaid Abd Al-Hadi SubscriberThank you!
- The topic ‘Material definition in MAPDL’ is closed to new replies.
                        1487
                        1363
                        1189
     You are navigating away from the AIS Discovery experience
