June 16, 2023 at 8:00 am
Chandra Sekhar Narra
SubscriberHi all,
I have a question about the temperature input in Ansys Workbench. Is it possible to give y=m*x+c as a linear temperature function along the length of the structure in Ansys?
Thanks in advance!
Kind regards
Chandra
June 16, 2023 at 9:17 am
Sampat Kumar
Ansys EmployeeHi Chandra,
as far as I can understand, you want to enter the temperature value along the length. There is a way that you can enter the temperature value along the length. You should know the temperature value along the length and enter the tabular form in the Ansys mechanical. Go to the temperature details, select the tabular data in the magnitude cell, and select the axis along the length in the independent variable cell.
Sampat -
June 16, 2023 at 10:23 am
SubscriberHi Sampat,
Thank you very much for your response. With the video you attached, I understand it now.
Kind regards
Chandra
June 16, 2023 at 1:31 pm
Sampat Kumar
Ansys EmployeeYou're welcome!
I'm happy to help you.
Sampat
- The topic ‘Temperature profile input’ is closed to new replies.
6465
