Ansys Learning Forum Forums Discuss Simulation Fluids How do you correctly import a mesh from ANSYS Fluent 2021R2mesher to the solver? Reply To: How do you correctly import a mesh from ANSYS Fluent 2021R2mesher to the solver?
Keyur Kanade
Did you use 2021R2 for Fluent Meshing?
Can you please check 2023R1 for both Fluent Meshing and Fluent Solver?
You can directly switch from Fluent Meshing to Fluent Solver using 'Switch to solution' option.
Please go through help manual for more details
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
