May 25, 2023 at 6:38 pm
Tạ Huy
SubscriberDear FLUENT ANSYS Support Team and researchers,
I hope this message finds you well. I am currently working on a simulation project where I need to set up an equivalence ratio of 0.6 for a methane-air mixture. The combustion model I am using is finite rate/eddy dissipation.
Could you please guide me on how to configure the necessary settings to achieve this in FLUENT 2020R2? Specifically, I would appreciate instructions on how to define the species, reactions, and operating conditions required for the simulation. Additionally, I would like to know how to set up the equivalence ratio using the finite rate/eddy dissipation model.
Any assistance or guidance you can provide would be highly appreciated. Thank you in advance for your support.
May 25, 2023 at 7:31 pm
RK
Ansys EmployeeHello,Â
I would suggest to over this tutorial: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/flu_tg/flu_tg_magnus.html
July 30, 2023 at 12:10 pm
ARN
Subscriberwhat should be done if equivalence ratio is 0.1 when air is the inlet and fuel is pure hydrogen in ansys fluent?
- The topic ‘EQUIVALENCE RATIO’ is closed to new replies.
5899
1306
