Ansys Learning Forum Forums Discuss Simulation Fluids Deformed geometry by adjoint solver Reply To: Deformed geometry by adjoint solver
Murari Iyengar
If you are using Design Tool, then I recommend you start with a smaller change so you can see how the mesh is getting affected. Else, by using Gradient Based Optimizer, you can specify minimum cell quality and set target so Adjoint solver will automatically keep iterating till target/conditions are met. Please look at 43.2. Using the Adjoint Solver (ansys.com) for more information.Â
