Ansys Learning Forum Forums Discuss Simulation Fluids Lift coefficent exactly 10 times smaller Reply To: Lift coefficent exactly 10 times smaller
Federico
So how are you getting Cl/Cd from the force in CFD-Post? I suspect you are not using the same reference values. You can check the ones used by Fluent in Physics tab > Reference values
