Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Frictional Contact › Reply To: Frictional Contact
May 25, 2023 at 7:56 am
Ah the node reduction helped to reduce time ,thanks much!
Yes, i tried to add more steps and also change the time steps and iterations here, could finally see the block fly off. Will try to work towards modifying the frictional coefficient for the part where it is sticking vs when it starts to slide now.
thank you
