Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Define user_derfined_viscosity MAT_SPH_VISCOUS › Reply To: Define user_derfined_viscosity MAT_SPH_VISCOUS
May 22, 2023 at 11:00 pm
Ushnish Basu
Dear WooMin,
You can use DEFINE_ADAPTIVE_SOLID_TO_SPH to transform a solid element to an SPH particle, though the material properties will be taken from the original solid element.
If you want your material to behave more like a fluid after yielding, you can just define it appropriately in the material routine itself, no need to call a separate routine.Â
f3dm9sph_userdefin is called from within MAT_SPH_VISCOUS, and it;s not meaningful to call it from elsewhere.
