November 28, 2017 at 6:38 pm
cfd_learner
SubscriberHI,
I would like to simulate a heating mat made of heating wire and fiber (cloth). How can I see the temperature rise in cotton/cloth sheet? I assumed cloth as rigid, any porosity etc is neglected. Only interested in heat transfer from heated carbon wire (50 degC) to the cloth sheet (assumed rigid/solid).
How to model this problem and appropriate boundary conditions? A picture is uploaded.
Regards
November 28, 2017 at 8:43 pm
pgl
Ansys EmployeeHere's a video showing how to model the heating element/wire:
https://youtu.be/r0ExkMyFedc
Here's an electro-thermal actuator example.: https://www.youtube.com/watch?v=ZAuI5AoOG4U your case will not expand anywhere near as much but the principles used here are the same.
All the best.
November 28, 2017 at 11:32 pm
peteroznewman
SubscriberHere is a Steady State Thermal analysis.
A single coil of the thermal mat is created in SpaceClaim in a multibody part.
The hexagonal coil is 1 mm thick and is embedded in a solid that is 4 mm thick.
A mesh that has less than 32K nodes+elements is created to stay within the Student license limits.
The coil has a Temperature BC of 30 degrees C
The front faces of the mat and coil have a convective BC. I just made up a Film Coefficient, you may want experimental data to support this.
The bottom and side faces of the unit square of the mat have a perfectly insulated BC. The temperature is plotted below.
You can pattern the coil to create a model closer to your example with multiple coil segments.
Having multiple coils or coil segments doesn't change anything except the mesh size.
Best regards,
Peter
November 29, 2017 at 12:28 am
cfd_learner
SubscriberThank you Peter. Kindly share the WB project. What actually embed means in geometry modelling? Merge or share topology ?
November 29, 2017 at 1:28 am
peteroznewman
SubscriberThe file extension that was .wbpz had to be changed to .txt because the website doesn't allow a .wbpz file extension to be attached! After you download the file, rename it from .txt to .wbpz then Restore Archive using ANSYS 18.2
In SpaceClaim, there are two bodies in one component and Share Topology was set for the component.
November 29, 2017 at 2:31 pm
cfd_learner
SubscriberThank you, Peter, for your prompt response. One more question, why bottom and sides are "Perfect Insulation"? what if all is convective? Will convection coefficient play any role, increasing or decreasing? Actually, I am new to "heat transfer".
November 29, 2017 at 4:43 pm
peteroznewman
SubscriberIf you are new to heat transfer, you could learn the basics of conduction and convection in Module 1 of this free course.
I used "Perfect Insulation" on the four sides to create a symmetry boundary condition to represent what any place that was not near the edge of the mat would look like. If I take my result and copy and paste it 3 times I can get a 2x2 image. Notice that the temperature contours intersect the boundary of the unit square at right angles. That is because no heat is flowing through the plane of symmetry. If I want to see how that is different at the edge of the mat, I could take one side and change that to convection.
As for the bottom face, I set it to perfectly insulated to represent it being in contact with insulation.
I could have set it to convection to represent air being in contact with the back as well as the front.
It just depends on what your model is trying to represent. You can play around with the Film Coefficient to see the effect that has on the result.
In my model, there is almost no temperature gradient through the thickness. If you can make the assumption that the temperature is uniform through the thickness, then you can change from a solid model to a surface model and use shell elements. This will enable you to model a much larger portion of the mat without exceeding the node+element limits.
Cheers, Peter
- The topic ‘Heat transfer analysis of heating mat’ is closed to new replies.
5824
1305
