November 1, 2017 at 10:52 am
Rana Nasser
SubscriberI'm doing a simulation in transient structural in workbench and I have a problem with importing acceleration-time history from excel-2016 into WB 15.1. I tried to import the data in ".XML" formats or ".txt" format ,but all my trials gave this error "'either the specified location is incorrect or the source at that location contains no data". Could you help me , please?
November 1, 2017 at 11:59 am
November 1, 2017 at 2:00 pm
Rana Nasser
Thank you so much Eng. peteroznewman, It is working!
But now I want to ask 2 new questions,
First, in the details of acceleration in the definition part I don't have the "Base excitation" cell, so what is the reason for this in your point of view?
Secondly, when I solved the model after pasting the acceleration time history data the error in the attached picture occurred when the model geometry is symmetric and the damping ratio was program controlled and its vale was .005. could you please tell me what's the meaning of "MSUP" ? and do you have any suggestions to fix this error?....... Thank you again Sir!
November 1, 2017 at 2:40 pm
peteroznewman
SubscriberI don't see a Fixed Support in your Transient branch.
When I build a Transient Structural model to simulate a seismic test of a piece of equipment bolted to the floor, I need that fixed support to hold the parts to ground. The acceleration load acts on the mass of the parts.
Here is the acceleration in Y. This is what an accelerometer on the fixed support would record.
Here is the y-displacement at the tip of a cantilever beam subject to that acceleration.
MSUP = Modal Superposition, which is a different solution method than Full Transient.
Block D is a Full Transient solution, while Block F is a Modal Superposition Transient solution.
Full Transient can simulate frictional contacts opening and closing and large deflection.
MSUP is a linear solution and can't do that, but it can solve linear problems much faster than Full Transient.
November 1, 2017 at 4:04 pm
Rana Nasser
SubscriberEng. Peteroznewman you are so kind and helpful man. Thanks for illustration, it was useful to me. Thank you so much for your time!!
November 2, 2017 at 9:36 am
magednasr668
Subscribersalam 3aliekm rana ....i am maged adel from egypt too and i am so glad there is one from my country here can you contact me please ..my facebook s ( civilian maged ) ..sorry for inconvenience
November 13, 2018 at 11:01 am
asma
SubscriberI want to know how to use PMV with heat and moisture and co2 ansys
November 13, 2018 at 12:39 pm
peteroznewman
SubscriberAsma,
Please post a New Discussion with this question. Delete this reply to this Discussion as it is off topic and already solved.
Kind regards,
Peter
- The topic ‘Importing acceleration time history data’ is closed to new replies.
6415
