There is a line creation error
    • walaakm10
      Hello everyone
      I created a line between these two points using .
      But when I select this line to use it to create a surface, this message occurred and the surface is not created, and then the file failed in ANSYS.
    • walaakm10
      Even when I neglect this line and delete it, and tried to create the surface using other lines, the surface fails. Does anyone have an idea about what the error could be?
  • The topic ‘There is a line creation error’ is closed to new replies.
