September 14, 2017 at 12:38 am
mckoz
SubscriberHi all,
I am attempting to create a conditional statement in CFX-Pre using CEL, either the step() function or an if() statement. Basically, I am running a Non-Newtonian simulation and some of the results of my simulation fall outside of the shear rate range specified within the CFX Non-Newtonian model. I am attempting to assign a constant value to the Dynamic Viscosity if the shear strain rate (sstrnr) is less than 0.001 s^-1, which is the lower limit of CFX. If the shear strain rate is greater than or equal to 0.001 s^-1, I would like for my Non-Newtonian model to be applied. I would like to do this because there are a few areas in my geometry that have shear strain rates lower than 0.001s^-1, and it is yielding unrealistically high viscosity results. Thus, for these regions, I would just like to assign some constant value of viscosity to make up for this.Â
Does anyone have any ideas about how I could do this? Thanks in advance.Â
November 2, 2017 at 8:58 pm
raul.raghav
SubscriberI assume you are trying to model the Non-Newtonian fluid using the Ostwald de Waele model. I could be wrong but I don't think you can assign a specific value for dynamic viscosity if the sstrnr goes below a certain value.
If I were in your shoes, I would write an expression for the the dynamic viscosity and bound the lower limit of the shear strain rate such that if sstrnr < 0.001 s^-1, I'd assume it to be 0.001 s^-1. So wherever your shear strain rate would be less than 0.001 s^-1, the dynamic viscosity will be calculated at sstrnr = 0.001 s^-1. The following CEL expressions would bound the lower and upper limits of sstrnr and implement the dynamic viscosity as an expression.
dynVisc = K * ((L * bSSTRNR)^(n-1))
bSSTRNR = if(sstrnr < 0.001 [s^-1], 0.001 [s^-1], cond)
cond = if(sstrnr > 1000 [s^-1], 1000 s^-1, sstrnr)
K - viscosity consistency; L - time constant; n - power law index; bSSTRNR - bounded sstrnr
November 3, 2018 at 3:51 am
November 15, 2018 at 6:59 am
Amine Ben Hadj Ali
Ansys EmployeeDo you have problems with the expressions or with the setup itself?Â
- The topic ‘CFX Expression Language Question’ is closed to new replies.
- affinity not set
3907
1414
1256
1118
1015
