Ansys Free Student Software
Problem with CFX, application failed to connect
    • Maria Bregianni
      Hello, I need to use Ansys the student version for my master but I am facing a problem while using CFX, and I cannot get to the Setup. This is what pops up:
      Could you please help?
      Thank you
    • George Karnos
      Uninstall the Student Version.
      Rename the Ansys Inc directory un c:\Program files\ to Ansys_Old
      Reinstall the Student Version by right click ->run as administrator.
      If that does not work, try running with firewall shut down as a test.
    • ALJA'AFREH MU'NIS KHALED AHMED
      Greetings,
      I have the same problem and the solution that you provided did not work. What should I do to fix that issue?
  • The topic ‘Problem with CFX, application failed to connect’ is closed to new replies.
