How to run Fluent on Linux Server without GUI
    • raushan79
      Dear Sir,
      I have installed Ansys 2023R1 on the server CPU working with Ubuntu 20.04. Now, I want to know how to run Fluent on the same platform using the command line as the server has no GUI option.
      Thank you
      I'd start here https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/flu_ug/flu_gs_starting.html   Set the model up locally with a GUI and then launch onto the cluster with a journal to issue the number of iterations etc.
  • The topic ‘How to run Fluent on Linux Server without GUI’ is closed to new replies.
