February 28, 2017 at 9:14 am
Nikita
Ansys EmployeeHow can I select one or more objects, such as faces in SpaceClaim?Â
July 21, 2017 at 6:11 pm
pgl
Ansys EmployeeYes!
You can select one or more objects quickly and easily by using the Select Tool. Click the first face of your design, hold down the Ctrl key, and then click each individual selection you want to add to or remove from your original selection. For more information, refer to the SpaceClaim Online Help.
- The topic ‘Is there an easy way to select multiple faces on a model in SCDM?’ is closed to new replies.
- Add-in Error Excel
- Fileformats
- Discovery 2025r2 failed to initialize
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
1495
1386
1209
