3D Design
3D Design
Post-processing in Discovery
    • eric.s.bish
      Hi, When attempting to simulate the external flow around a building using Ansys Discovery, I encountered the following questions: (1) I want to display contours of static pressure on the building faces only, but this does not seem to be possible with Ansys Discovery. (2) I want to display velocity vectors on a cut plane, but this does not seem to be possible with Ansys Discovery. As an alternative I used the "direction field". Can you please advise? Thanks.
    • Nick Stefani
      Hi Eric,
      For the first question, you could select in the countours settings: Location: All faces, Surface Display Priority: Inner and in this way you should be able to see the building faces.
      For the second question, yes i do not think you can see vectors on a plane and yes direction field would probably be the closest option.
      I hope this helps.
      Best regards,
      Nick
    • eric.s.bish
      Thanks for your quick reply, Nick.
      I tried your suggestion for my model, and I was able to successfully display the building pressure contours in EXPLORE mode (see below) but not in REFINE mode. In REFINE mode I do not get "inner" as a surface display priority (see second image).
      I'm not sure what is the matter.
    • Nick Stefani
      Hi Eric,
      You are right, Inner surface results seem to only be available in explore at the moment. I will try to check if there is a workaround and let you know.
      Best regards,
      Nick
    • eric.s.bish
      Thanks!
Viewing 4 reply threads
  • The topic ‘Post-processing in Discovery’ is closed to new replies.
