October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeThe contact should be checked properly. The nut surface has bonded contact with flange and the same face shares the edge with another bonded contact between nut & bolt. It is recommended to create proper contact. Split the faces so that contact and target face should become one-to-one match.
October 4, 2017 at 2:39 pm
nselvara
Ansys EmployeeReaction forces on nut surface are not equal and lesser than the bolt pretension applied
- The topic ‘Reaction forces on nut surface are not equal and lesser than the bolt pretension applied’ is closed to new replies.
Ansys Innovation Space
- APDL, memory, solid
- Meaning of the error
1414
1236
1118
1015
