Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › An error occurred inside the POST PROCESSING module › Reply To: An error occurred inside the POST PROCESSING module
April 14, 2023 at 10:30 am
THANK YOU ASHISH, I AM NOT USING COMMAND OBJECT.Â
when i am trying to evaluate contact tool i am facing troubles with it ''an error occurred inside the POST PROCESSING module'' , after i chaneged the reinforcemnt bar model type from ''reinforcement '' to ''beam'', i got results with contact tool.
its quite complex model though i am searching for a linear results.
